popping
Old Nov 10, 2003 | 09:32 PM
BigBearAddict's Avatar
Default popping
Does anyone else that owns a shaft drive utility hear a slight popping noise from the driveshaft when going over rough terrain or such...??
Old Nov 10, 2003 | 10:09 PM
Default popping
I guess nobodys going to look at this
Old Nov 13, 2003 | 08:44 AM
lippysmac's Avatar
Default popping
I've not heard any noises yet and I'm not an expert on the situation but, You may want to check you diff fluid. Also I'm not certain but check for grease nipples in the u-joints. If they are on the 2wd grease them and see if the noise stops. If all else fails call the dealer and see what they say.
Old Nov 13, 2003 | 03:17 PM
action450s's Avatar
Default popping
I'd say that you have a CV or U joint on its way out. Check all sahft boots for wear tear and cracks, check for grease nipples, most likely will have to replace worn parts by now if they're cracking like that.
Old Nov 13, 2003 | 03:41 PM
hondarulesinnc's Avatar
Default popping
It might be either the swingarm bearing/bushings or axel bearings cause on my recon both the swingarm and axel bearing wore out from mostly mud and some of the rough trail riding. so you might want to cheak them out. it starts out as a slight poping and gradually gets worse entil you are forced to replace them
Old Nov 13, 2003 | 06:20 PM
Default popping
well its only about 3 months old, and its under warranty...so i should just tell my dealer to check out the bearings?
Old Nov 14, 2003 | 03:42 PM
Default popping
That sound like a good idea. It might be that the swingarm needs to be greased and tightened up a little
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
r1pilot83
Sep 27, 2015 07:38 PM
Rooky
Sep 9, 2015 03:16 AM
