why wont it start?
Old Nov 11, 2003 | 01:39 AM
simster570's Avatar
Default why wont it start?
Hi I own a 2000 Suzuki Quadmaster 500. When I try to start it, it just turns and turns and doesnt even try to start. When I got it 1 week ago, it started up great, but slowly, it has become harder and harder to start. Now I cant even get it at all. I think it may have something to do with the choke, but I dont know for sure.
Also, it doesnt idle. When I get it to start(rarly) I have to continually give it gas or it will die. It will not idle or even try to idle at all. Please help I need to go hunting this weekend!
Old Nov 14, 2003 | 07:24 PM
roscoe69's Avatar
sounds like fuel problems, lack of fuel makes it hard to start , and then wont idle . check to see if it has a fuel filter ? sometimes spraying a little fuel into the intake wil lhelp . I use a old manuel windex bottle. give this a try or just pour a little into the intake and then try starting.
Old Nov 15, 2003 | 12:33 AM
trailride's Avatar
check your plug also. its a cheap fix if thats what it is
Old Nov 17, 2003 | 01:11 AM
kennyboi's Avatar
check to see if you r gettin gas to the carb, if that aint it check to see if the spark plug is sparkin, if that aint it, clean your jets, and if that aint it, it got to be something wrong with the wiring somewhere check the key switch and kill switch first.
Old Nov 25, 2003 | 08:15 PM
CATDOG's Avatar
Have you checked your air filter?? and make sure your vent hoses arent crimped under your seat-I have had this happen before...worth a shot to try em all.
Old Nov 26, 2003 | 03:57 AM
akfireman's Avatar
one other thing to check, your fuel shutoff, i shut mine off while i was trailering it, got home, took it off the trailer and parked it. next time i wanted to ride, dang thing wouldnt run right, then died and wouldnt start, it would turn over fine but nothing, then it hit me DUH! I am an Idiot, i forgot to turn the fuel back on!!!!!!! needless to say no problems at all after that, ha ha ha.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
