Raptor Gearing
Old Nov 12, 2003 | 10:28 AM
XxDumontRaptorxX's Avatar
Default Raptor Gearing
Right now I have stock sprockets/2002 tranny. I pull 3rd easily up the hills with 20" 8 paddle tires. The question is, should i gear it down and pull 4th, or gear it up a bit and pull 3rd a little harder? Just want some opinions on what others are doing.
Old Nov 12, 2003 | 01:04 PM
Old Nov 12, 2003 | 01:26 PM
LOWBOWTIE's Avatar
I have the same paddle size as you and I'm gonna try 12/42 sprockets and run 4th gear.[img]i/expressions/face-icon-small-wink.gif[/img] If This works for me then I'll be able to run a 12/40 for when the sand is dry.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 12, 2003 | 09:44 PM
raptor03's Avatar
xdumont raptor i run the stock gearing now and i like it, at Glamis i was pinned a little much so i wanted to change to the14/40 which i will try thankdgiving at Dumont,i was pulling 3rd pretty good at dumont but i think i can pull it at dumont with the 14/40,if not the 13 is going back on..
Old Nov 13, 2003 | 09:13 AM
I was thinking the same thing, If i wanted to pull 3rd harder, i would prolly just jump down 2 teeth on the rear to pull 3rd harder(Doubt I would be able to pull 3rd with 14t front). I ordered a 12t and am going to see how it works out, was hoping to do it this saterday, but i doubt the sprocket will arrive on time. Maybe ill make a day trip during the week. If I dont like the way the 12t is working out, ill just pull 3rd harder with either 1 or 2 teeth drop on the rear sprocket.
Old Nov 13, 2003 | 03:32 PM
LOWBOWTIE's Avatar
Have you guys found a 38 or 39 tooth rear yet? I'm still look'in.
Firefighter400
Oct 8, 2022 06:38 PM
Ashley S
May 29, 2017 10:54 AM
black_thunder
Jul 26, 2015 09:23 PM
black_thunder
Jul 22, 2015 06:01 PM
black_thunder
Jul 9, 2015 05:58 PM
