ATV newbie with stupid question
Old Nov 15, 2003 | 09:36 AM
pmyeomansjr's Avatar
Default ATV newbie with stupid question
I just bought a 2001 400ex and I cant get it started.
I dont know if I am just stupid or what....
When I try to start it it just clicks. It doesnt even try to kick over.
Can some one help me out?
Thanks
Old Nov 15, 2003 | 10:07 AM
sickmojave's Avatar
it sounds like you may have a dead battery. make sure the cables are clean and tight. if you have a battery charger you may want to give it a try. if it's the original battery it may be time to relpace it.
Old Nov 15, 2003 | 10:30 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Can you still start it by pushing it and poping the clutch????
Old Nov 15, 2003 | 01:02 PM
ElectricShift's Avatar
Starter brushes....
Old Nov 15, 2003 | 08:09 PM
420EX's Avatar
dead battery
Old Nov 24, 2003 | 03:28 PM
BSA's Avatar
BSA
Dead battery. Charge it will a low amp charger designed for motorcycle/ATV batteries. A high amp auto charger will boil the battery.
If it has been sitting long enough for the battery to go dead, it probably needs a general maintenance check. Change the oil. Use motorcycle/ATV oil, not auto oil. Clean the air filter. Drain out the old gas (put it in your truck), especially the gas in the carb bowl. Blow out the carb with carb cleaner and refill the tank with fresh brand name gas. Add fuel line cleaner to the gas. Check the tire pressure.
Old Nov 24, 2003 | 03:43 PM
CassCor's Avatar
I'm not positive, but if the battery is indeed dead, you won't have any luck trying to start it. It needs a good battery to start. That happened to me not too long ago. The battery went dead on me and I had a friend pull me around trying to start it. It wouldn't fire till I charged the battery up some.
HTH
wendal
Oct 31, 2017 03:31 AM
bigred20653
Oct 2, 2015 10:05 AM
wendal
Sep 15, 2015 01:50 PM
that1redhead
Sep 8, 2015 11:47 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
