HD Rear Spring for Xplorer
Old Nov 17, 2003 | 12:23 PM
Kingman's Avatar
Default HD Rear Spring for Xplorer
I have a 1998 400 Xplorer and the back really sags on acceleration or when I have gear on the rear rack. Does anybody know where to get a Heavier Duty rear spring?
Old Nov 17, 2003 | 05:04 PM
chckmagnet18's Avatar
at the bottom of the shock there is an adjuster if you buy or have a tool you can adjust it so its a harder ride which is what i have done. hope that helps
Old Nov 17, 2003 | 05:05 PM
Snownut's Avatar
A friend of mine just changed out his hd springs for some lighter ones. The ones he was using are off a 96 sportsman 400. I think they are the same... I will see if he still has them. His complaint was that they were too stiff.
Old Nov 17, 2003 | 05:13 PM
Kingman's Avatar
I have the adjuster set to the firmest setting and it still compresses terribly. I have read that Polaris makes some HD springs, but I don't know if they make them for the xplorer since it has a single rear spring and shock.
Old Nov 17, 2003 | 05:26 PM
Snownut's Avatar
Kingman, the 95-96 sportsman 400's and the explorers were pretty much the same frame with one rear mono shock in the rear.
merryman
Jan 19, 2016 04:29 AM
Polaris5
Aug 29, 2015 09:11 PM
cornermike
Jul 30, 2015 06:37 AM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
