What pressure is best in ITP 589's?
Old Nov 18, 2003 | 07:37 PM
NascarFan's Avatar
Default What pressure is best in ITP 589's?
Old Nov 18, 2003 | 07:41 PM
NascarFan's Avatar
I have a new set of 589's and I'm used to just pushing on the rear tires with my foot to check the pressure is about right. With these tires they seem so stiff that I can't tell with the foot test. What pressures are you guys with 589 tires running?
Old Nov 18, 2003 | 11:17 PM
Coyotechaser's Avatar
Since nobody has answered you, I'm going to guess and then maybe someone will correct me and you'll get your answer. The recommended PSI is 7 for 589's so I'd run about 5 psi depending on where you're riding. (rocks, hardpack, etc..) If I was going to ride on rocks then I'd probably drop it 1 or 2 more. Once again, I don't have 589's and it's just a guess.
Old Nov 19, 2003 | 12:44 PM
action450s's Avatar
I have Blackwaters, I never run more than 3 PSI in those tires with no load on the bike. Too much air and the tires will be very jumpy at speed on the bumps, will wear the centers of the tread, and will provice less traction as the only part of the tread touching is in the middle.
If you have a load of gear on or in tow, use more, example hauling out game after hunting.
Old Nov 19, 2003 | 01:29 PM
Camo-man's Avatar
I run between 4 and 4.5 lbs....
Old Nov 19, 2003 | 01:34 PM
Bobmack's Avatar
I run 6 lbs.
Old Nov 19, 2003 | 04:27 PM
TrEvIn's Avatar
Not sure what we are running. We mostly go by the foot test but as you said they are pretty stiff. If they look like they got enough air and it rides good it must be good!
Old Nov 19, 2003 | 05:46 PM
bullett's Avatar
most people run 5-7lbs in them....
bmxatv10
Oct 14, 2022 06:23 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Hw00d
Sep 10, 2015 08:53 AM
