250TB Misses at full throttle
Old Nov 19, 2003 | 08:01 AM
JakTrailboss's Avatar
Default 250TB Misses at full throttle
Got an 86 Trailboss 250, she misses from about mid to full throttle. Otherwise it runs great, starts very easy, idles great, plenty of power from idle to mid throttle - then slightly misses - never gets up to full speed. Change the plug already. Took the carb apart and gave it a good bath in carb cleaner. What would you guys think the problem might be?
Old Nov 19, 2003 | 08:39 AM
fishslab's Avatar
what kind of compression you got on it? May be goin bad on top end. Fuel filter been changed lately? Are you gettin good fuel flow? Is the fuel petcock filter plugged in the tank? Just some ideas of stuff to check.
Old Nov 19, 2003 | 08:41 AM
quadwrench's Avatar
Sounds like the reverse limiter - don't have my book handy or I would tell you how to "bypass" to verify. I'll try to remember it this evening.
Old Nov 19, 2003 | 09:22 PM
Iggysoil's Avatar
Check the main jet. I bet its to big. That old of a quad maybe the reverse limiter.
Old Nov 20, 2003 | 01:09 PM
GrimRipper's Avatar
Sounds like it's jetted too rich.Try a clean air filter or remove it for just a bit and see if it staightens out.
Old Nov 20, 2003 | 08:11 PM
2manytoys's Avatar
You need to find out what main jet you have in it. This will absoluitly make it miss from mid-top because of it being too rich. Are there any other mods done to it? Is it all stock? It is very possable that a previouse owner jetted it for winter and never changed it back. Going up 1 full size on the main in a stock machine will make it miss.
Old Nov 20, 2003 | 10:44 PM
quadwrench's Avatar
On those old TB's the reverse limiter is located on the front part of frame, in front of / underneath the gas tank (you should be able to get to it without tank removal), it is kind of square box looking.
There is a 2 pin plug with a green and black wire - if you disconnect the black wire going to the box, the reverse limiter will be taken out of the loop. If you decide to leave it this way, just remember that reverse will be just as fast as forward speeds.
I've seen numerous old TB's that had this problem, besides it's a lot easier to address first before tearing into the carb and rejetting.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
blpersinger
Jul 15, 2015 09:56 PM
Sjrpp
Jul 5, 2015 09:04 PM
