250R fouling plugs
Hello, I'm new here.
I have an 86 trx 250R that keeps fouling plugs on me. When the plug fouls i can clean it up with a wire brush and it works. The carb jetting was to rich when I bought the bike so I leaned it out some. I have good spark but it still fouls plugs about every other day. The carb is a duncan racing PJ. When I bought this bike, i noticed it didn't have a voltage regulator on it. Could this be the problem? It runs fine without it.
I had this problem with mine also. I just put a oversized cylinder on and new piston, changed my 2-cylcle oil. Have not fouled one yet. I do sputter on the low end. Any idea on that. it screams on the top end.
I'm using golden spectro oil at 40:1. I fouled 2 plugs today??? It seems to be getting worse. When I'm riding it will act like it just shuts off. I replaced the cdi box and coil but had no time to ride it and see if it worked. It seemed to start better. One thing I did notice is when I kick it over to check the spark it sparks good but right after I kick it, it will spark again when the motor isn't turning? Will it hurt the new coil and cdi box if I'm not running a voltage regulator?
i too have this problen on my suzuki right now.
i have checked jetting,carb float levels,had the lower end completely rebuilt, top end rebored and new piston,tried hotter spark plugs. it did this before the rebuild and still after [img]i/expressions/face-icon-small-sad.gif[/img] only thing left to check on mine is the electrical when i check my spark it looks like it should spark more than it does.
