250R fouling plugs
Old Nov 19, 2003 | 08:48 PM
rerard's Avatar
Default 250R fouling plugs
Hello, I'm new here.
I have an 86 trx 250R that keeps fouling plugs on me. When the plug fouls i can clean it up with a wire brush and it works. The carb jetting was to rich when I bought the bike so I leaned it out some. I have good spark but it still fouls plugs about every other day. The carb is a duncan racing PJ. When I bought this bike, i noticed it didn't have a voltage regulator on it. Could this be the problem? It runs fine without it.
Old Nov 19, 2003 | 09:43 PM
DaBeechMan's Avatar
you might have a leaky right crank seal. Usually a slightly fat carb wont take a plug out in 1 day.
Old Nov 20, 2003 | 02:29 AM
rerard's Avatar
would a leaking crank seal cause the trany oil to burn away and be low? The plug isn't oily looking?
Old Nov 20, 2003 | 02:32 AM
DaBeechMan's Avatar
of course it would. it usually wont be oily. Just fouled. Sometimes blackish
Old Nov 20, 2003 | 03:35 AM
URCRAZY's Avatar
I had this problem with mine also. I just put a oversized cylinder on and new piston, changed my 2-cylcle oil. Have not fouled one yet. I do sputter on the low end. Any idea on that. it screams on the top end.
Old Nov 20, 2003 | 05:04 PM
dragracer789's Avatar
Yes, what kind of oil are you mixing it with. Mix it at 40:1 for all around use. some great brands are red line, amsoil, klotz, golden spectro, or any other name brands. Dont just use chain saw oil.
Old Nov 20, 2003 | 08:15 PM
rerard's Avatar
I'm using golden spectro oil at 40:1. I fouled 2 plugs today??? It seems to be getting worse. When I'm riding it will act like it just shuts off. I replaced the cdi box and coil but had no time to ride it and see if it worked. It seemed to start better. One thing I did notice is when I kick it over to check the spark it sparks good but right after I kick it, it will spark again when the motor isn't turning? Will it hurt the new coil and cdi box if I'm not running a voltage regulator?
Old Nov 20, 2003 | 08:20 PM
HA2's Avatar
HA2
ive been riding golden spectro at 40:1 for the past season and my two uncles ran if for years on their trikes, this isnt your problem. you got me stumped.
Old Nov 20, 2003 | 09:53 PM
DaBeechMan's Avatar
you need to break down and check your seal. 2 plugs in a day isnt right. You could run 16:1 and not foul 2 plugs in a ride.
Old Nov 21, 2003 | 11:29 AM
evhwg's Avatar
i too have this problen on my suzuki right now.
i have checked jetting,carb float levels,had the lower end completely rebuilt, top end rebored and new piston,tried hotter spark plugs. it did this before the rebuild and still after [img]i/expressions/face-icon-small-sad.gif[/img] only thing left to check on mine is the electrical when i check my spark it looks like it should spark more than it does.
