250x
Old Nov 20, 2003 | 08:30 PM
440exhondasrock440ex's Avatar
Default 250x
hi guys, does anyone here know what the displacement is on a stock 250x
Old Nov 20, 2003 | 08:45 PM
BRAD14's Avatar
Default 250x
its 230somethinnnot sure the exact but it is in the 230's
Old Nov 21, 2003 | 01:05 AM
dork's Avatar
Default 250x
its 246 cc's.
Old Nov 21, 2003 | 01:30 AM
Slacker1bob's Avatar
Default 250x
Yup,
246cc
Old Nov 21, 2003 | 08:43 AM
kwackermann's Avatar
Default 250x
The following specifications were published in Honda's 1991-1992 service manual.
Displacement: 246.4cc
Bore & Stroke: 74mm & 57.3mm
Compression: 9.4±0.2:1 (185 ±14.2psi cold cranking)
Carburetor: 36mm
Lubrication: wet sump, pressurized
Ignition: CDI
Ignition timing: 23°±2°BTDC/3,000±200RPM
Starter: forward kick
Transmission: 5-speed manual clutch, plus reverse
Transmission ratios: primary 2.833 (68/24), 5th 1.178 (33/28), 4th 1.458 (35/24), 3rd 1.857 (39/21), 2nd 2.529 (43/17), 1st 3.692 (48/13), final 2.923 (38/13)
Final Drive: #520 chain, O-ring sealed
Overall Length: 1,720mm (67.7")
Overall Width: 1,105mm (43.5")
Overall Height: 1,085mm (42.7")
Seat Height: 770mm (30.3")
Footpeg Height: 325mm (12.8")
Wheelbase: 1,225mm (48.2")
Ground Clearance: 125mm (4.9")
Dry Weight: 164kg (362 lbs), engine only: 39.2kg (86.4 LB)
Curb Weight: 170kg (375 lbs)
Maximum Weight Capacity: 120kg (270 lbs)
Fuel Tank Capacity: 8.5 liter (2.3 gal) including reserve
Front Wheels: AT22x7-10 aluminum rims with 4 on 144mm bolt pattern
Rear Wheels: AT22x10-9 aluminum rims with 4 on 110mm bolt pattern
Brakes: triple hydraulic disk, single piston caliper designs
Front Suspension Travel: 170mm (6.7"), double wishbone, adjustable preload
Rear Suspension Travel: 200mm (7.9"), decarbon-type damper, adjustable preload
Caster: 8°
Camber: 0°
Trail: 35mm (1.4")
Toe-in: 10mm (0.4")
Turning Radius: 3.2m (10.5')
The displacement is 246.6 cc
Hope this hleps....[img]i/expressions/face-icon-small-cool.gif[/img]
Old Nov 21, 2003 | 02:25 PM
Default 250x
cool, thats all i needed thanx guys
big_g_squared
Jun 28, 2015 04:17 PM
rockrider
Feb 20, 2001 02:51 AM
owen350x
Jul 30, 2000 01:58 AM
99_warrior_350
Jun 26, 2000 04:50 PM
YellaTerra
Mar 30, 2000 04:38 PM
