stock 250r loc nut stuck
Old Jun 18, 2000 | 03:19 PM
b(250rman)'s Avatar
alright I got my durablue eliminator axle adjustable width from stock to +2 (I have had the axle about 2 weeks now) and I just got durablue posi loc axle nut. I got the brake caliper and the chain off the problem is I can't get the stock axle nut off I have a big pipe wrench and all it does iss lift the atv off the ground.I can't get off for nothing. anyone have any tips?? any help would be GREATLY appreciated
Old Jun 18, 2000 | 03:25 PM
hot_shoe_cv's Avatar
You might try using a breaker bar made of a 2 0r 3' piece of pipe just big enough to fit over the pipe wrench. You may need to have some one sit on the quad to keep it from lifting
Old Jun 18, 2000 | 03:28 PM
b(250rman)'s Avatar
I have used a piece of sqaure steel tubing about 2 foot long and had my chunky pal sit on it to no aval.
Old Jun 18, 2000 | 03:33 PM
veedell's Avatar
Are you trying to back the axle nut OVER the clip that you tighten the nut up too? A friend of mine did the same thing one time.
jason
96 350XX
#94 MHSC
#401 SOIL
Old Jun 18, 2000 | 03:38 PM
b(250rman)'s Avatar
I am trying to loosen the nut on the side of the caliper first and then back the smaller nut off alittle and take out te clip is this right.
Old Jun 18, 2000 | 03:42 PM
veedell's Avatar
You back the smaller nut off first, that means you would be loosening it towards the caliper, then you would back the larger nut towards the caliper also until it's far enough back for you to get the clip off, then take both nuts off towards the hub side. Easier said then done sometimes too. I have had my fair share off problems with axles.
jason
96 350XX
#94 MHSC
#401 SOIL
Old Jun 18, 2000 | 03:45 PM
b(250rman)'s Avatar
thanks but should I lift up on the wrench or push down since it is reversed threaded i am confused
Old Jun 18, 2000 | 03:47 PM
Have you tried heat? A propane torch should work along with your other option after heating.
Don't take this to the bank, but I'd think the thread would be a right hand thread so that the counter- clockwise rotation of the axle will tend to tighten the nut. Therefor If such is the case you'd need to loosen the nut counter-clockwise
Old Jun 18, 2000 | 03:52 PM
veedell's Avatar
That's a good idea too with the torch. I always spray WD40 on it and let it sit for awhile too. The threads are reversed so you need to,.......(Hmmm let me think here............) ok, I think you will take your pipe wrench and loosen the small nut with the wrench on top pushing down on it, or turning it counter clock wise. Make sure if you're using a monster pipe wrench that it's not catching the larger nut too, that would make it impossible to loosen also.
jason
#94 MHSC
#401 SOIL
Sure wish someone knew something about spindles?
Old Jun 18, 2000 | 03:56 PM
b(250rman)'s Avatar
we have a ocyetalyne torch or however U spell it and I was thinking about heating it up but I have a new carrier seals and bearings and don't want to get them hot. I have tried everything from wd-40 to airfilter oil .we were thinking just cut the old axle off hmmm but I don't know yet.
