stock 250r loc nut stuck
alright I got my durablue eliminator axle adjustable width from stock to +2 (I have had the axle about 2 weeks now) and I just got durablue posi loc axle nut. I got the brake caliper and the chain off the problem is I can't get the stock axle nut off I have a big pipe wrench and all it does iss lift the atv off the ground.I can't get off for nothing. anyone have any tips?? any help would be GREATLY appreciated
You back the smaller nut off first, that means you would be loosening it towards the caliper, then you would back the larger nut towards the caliper also until it's far enough back for you to get the clip off, then take both nuts off towards the hub side. Easier said then done sometimes too. I have had my fair share off problems with axles.
jason
96 350XX
#94 MHSC
#401 SOIL
jason
96 350XX
#94 MHSC
#401 SOIL
thanks but should I lift up on the wrench or push down since it is reversed threaded i am confused
Have you tried heat? A propane torch should work along with your other option after heating.
Don't take this to the bank, but I'd think the thread would be a right hand thread so that the counter- clockwise rotation of the axle will tend to tighten the nut. Therefor If such is the case you'd need to loosen the nut counter-clockwise
That's a good idea too with the torch. I always spray WD40 on it and let it sit for awhile too. The threads are reversed so you need to,.......(Hmmm let me think here............) ok, I think you will take your pipe wrench and loosen the small nut with the wrench on top pushing down on it, or turning it counter clock wise. Make sure if you're using a monster pipe wrench that it's not catching the larger nut too, that would make it impossible to loosen also.
jason
#94 MHSC
#401 SOIL
Sure wish someone knew something about spindles?
jason
#94 MHSC
#401 SOIL
we have a ocyetalyne torch or however U spell it and I was thinking about heating it up but I have a new carrier seals and bearings and don't want to get them hot. I have tried everything from wd-40 to airfilter oil .we were thinking just cut the old axle off hmmm but I don't know yet.
