Sportsman 500 HO Problem, HELP!
Old Nov 23, 2003 | 07:54 PM
DaveSP500HO's Avatar
Default Sportsman 500 HO Problem, HELP!
I have a '01 Sportsman 500 HO that isn't running right, anything over idle it starts cutting out badly, if I take the air box lid off it helps some, and if I also take off the air filter it helps more. I noticed that right after I shut it off there is a little gas dripping out of the overflow tube. I'm wondering if it would be the carb float out of adjustment, if so would that make it run poorly? Also what is the correct setting for the float?
Thanks in advance.
Old Nov 23, 2003 | 10:16 PM
Traildog's Avatar
It's probably a leaking needle valve that controls the level in the float bowl. If you shut off the gas and run it (with air filter and lid in place) the fuel level in the float bowl will gradually drop. When the level approaches it's "normal" level it will run normal until the you run out of fuel. If this test holds true all you need to do is replace the needle valve or it just may need cleaning.
Old Nov 25, 2003 | 08:30 AM
I took the bowl off the carb and everything looked clean, cleaned seat and needle. Reassembled still runs the same. The little test of shutting off the gas does let it run right for a few seconds before it runs out of gas. I should mention this is almost new machine with approx. 30 hrs.
Old Nov 25, 2003 | 09:57 AM
Farmr123's Avatar
Best thing to do then is let the dealer fix it.
If it always did this since new, the float may not have been set properly.
Farmr
Old Nov 25, 2003 | 10:09 AM
No, this has just started.
Old Nov 25, 2003 | 09:22 PM
Traildog's Avatar
Everything points to a float bowel level that is too high, the causes can be a leaking needle valve, a leaking float (if it is hollow) or the level is wrongly adjusted, not likely as it worked fine before. All in all I agree with farmr, take it back to the dealer that's what warranty is for.
Old Nov 27, 2003 | 08:47 AM
Problem solved! The underlying cause goes back to when I rejetted for my Colorado trip, I thought the foam that rests on the tank to hold the 2 plastic air breather tubes went up under the plastic atop the tank, soooo it was restricting the air intake, which then would help in fouling the plug so it would not run correctly with air breather top off. Glad to have that behind me. Live and Learn.
Old Nov 27, 2003 | 10:26 AM
Farmr123's Avatar
I should have thought of that. My Xplorer did the exact same thing. I have since taken that foam piece, and removed it. It is there to dampen noise, and if you really listen, it may be a little louder, but after restricting the intake 2 times I figured I could live with the noise.
skittero
35
Mar 1, 2019 12:39 AM
yellowpolaris
Jun 21, 2015 11:13 AM
UPLou
Jun 7, 2015 09:42 AM
May 27, 2015 11:15 AM
PolarisPower500
May 17, 2015 02:28 PM
