wolverine not riding straight
Old Nov 24, 2003 | 09:33 PM
bmwm5ive's Avatar
Default wolverine not riding straight
in order for my wolvy to go in a straight line, i hafta hold
the handlebars kinda crooked.
i dont mind it on trails but on the road it gets tiring.
how do i straighten it????
Old Nov 24, 2003 | 10:02 PM
95Wolverine's Avatar
well, sounds as if your alignment is off, or was once off and someone corrected it without having the handlebars straight.
Put your machine up against a wall, you should not be able to turn the steering either way if it is up tight... this is what you want. as for the back, do the same.. make sure it is tight against the wall.
Now, what you have done is make sure that the front wheel is aligned with the back wheel. if your handlebars are not straight when you sit on the quad, you will need to adjust your tie-rod lengths. be sure to adjust them equally.
Now, take it for a spin and see if it is better.
Finally, pull into the garage straight, put a jack under it, and draw a line down the center of the tread.. something you can get a tapemeasure across.. this line only needs to be about an inch long. Do this to both sides. Now with that line as far forward as it can go, using a tape measure, take a reading for the centerline to centerline distance between the front tires. Write that number down. Next, rotate that line 180 degrees or as far to the back as it can go. Measure again. The book states that the front should be around 1/4" narrower than the back.
If not in spec, adjust both tie-rods equally... or if you noticed that the handlebars were still off, fudge more to the side that is off.
Hope this helps.
Ride On.
Old Nov 24, 2003 | 10:27 PM
warrior007's Avatar
My bro-in law bought some 489 tires for his and found one of the front tires was a full 2" less diameter with the correct psi in both. defect or something..
just something to check also
Old Nov 25, 2003 | 12:29 AM
shastadog's Avatar
It also could be from the full time 4wd...Mine pulled a little before the 424 disconnect.
Old Dec 1, 2003 | 02:07 PM
BigBearFX's Avatar
check your tire pressure
Old Dec 23, 2003 | 09:54 AM
Aramis's Avatar
Mine was pulling to one side no matter how many times I tried to realign the front wheels.
Tire pressure was good.
It finally was a worn out bearing and ws easily spotted because when the wolverine was lifted off its wheels, the front wheel that had the bad bearing would be a little loose. you could wiggle it slightly...
After I changed both inner and outer bearings on that side, realigned it for good and been running straight ever since.
Aramis
Old Dec 24, 2003 | 03:47 PM
Eceriderjbomb's Avatar
you shoulent be on roads anyways[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 6, 2004 | 10:56 PM
cycletrash98's Avatar
My 99 wolverine did the same thing after i put a big foot kit on it, it does get tiring riding it all day. I bought works shocks, solved all my problems. Travels straight steers easier and finding more gears through the woods now!
Frisky2050
Apr 9, 2020 11:19 AM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
