Re-using crush washers & exhaust gasket on Pred
Old Nov 26, 2003 | 09:53 AM
Gottahavaraptor's Avatar
Default Re-using crush washers & exhaust gasket on Pred
I'm finally getting around to doing some mods on the Predator, so my header is at Jet-Hot right now getting the sterling coating, and I have an HMF on the way......question is, those of you who have had your exhaust apart, have you re-used the copper compression washers in the head, and the metallic gasket/sleeve between the header and factory muffler, or did you order new ones? Also, any suggestions on a good "bang for the buck" intake mod? FWIW, I've been considering the Hardrock set up. Thanks in advance.
Old Nov 26, 2003 | 09:50 PM
jsyi's Avatar
I think the best bang for the buck is the K&N clamp on fliter. Then take the airbox and turn it into a little storage box/ice chest or just remove it completely[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 27, 2003 | 01:16 AM
IBlameTheDog's Avatar
I like either the clamp on or naturally like my modded airbox setup check out the pictures but disregard the dirt it is not that dirty anymore.
Old Nov 27, 2003 | 02:20 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
as far as the crush rings go,,,,,,I would defenitely replace those.
They are not meant to be re-used.
Old Nov 27, 2003 | 08:37 AM
Hozed's Avatar
the exhaust gasket can be reused if you can get it out in one peice.. its a pain in the *** tho.
and i also suggest the k&n clamp on.. it gets that airbox out of the way.
Joe454
Nov 20, 2020 01:19 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Sep 10, 2015 01:56 AM
