1" wider tires, will it help cornering?
Old Nov 29, 2003 | 12:28 AM
flybub's Avatar
Default 1" wider tires, will it help cornering?
Hey all, I've been tearing up trails on my new rappy and thinking of investing in some rear tires. Once I got used to shifting my body weight the bike is not as tipsy, however, would 1" wider tires help stabilize the quad at all? I'm looking at some Maxxis Razr's and thinking of going 1 inch wider. Any experience with this would be appreciated. I mostly run trails and some mx.
Old Nov 29, 2003 | 01:58 AM
Yamaha660R's Avatar
I would go with Razr 2's.
And it will help some, but it's not that noticable. Still alittle tippy. But you seem to be used to it.
Old Nov 29, 2003 | 02:31 AM
UBETRUN's Avatar
New back tires will make a big difference if you get a brand with more squared shoulders. The stock tires roll a lot in the corners, Holeshots and Razrs will break loose before the sidewall rolls and that results in a more stable feel in the corners.
Old Nov 29, 2003 | 10:58 AM
scrambler420's Avatar
a set of wider a-arms will help it in the cornors alot..
Old Nov 29, 2003 | 11:19 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
A rim change will help even more thatn just tires!! I run Holeshots on ITP 9X9 rims. The rims are 1" wider than stock. They have 1" more offset than stock. And, the tires are 1" wider than stock. So, you get a 3+ rear end! The Holeshot fronts on ITP rims will also make the front 2+.
Old Nov 29, 2003 | 04:14 PM
honda400extreme03's Avatar
You will notice a little bit. But just buy the stock size. Your aftermarket tires will have a thicker sidewall wich gets rid of tire roll. Which in return gets you faster smoother and more stability. If you wanna go wider, go for it.
'03 400ex
K&N
Trail Tech Speedometer
Tag X-5 Handlebars
Oury Grips
Off Brand Wholeshot Tires
Shock Covers
Old Nov 29, 2003 | 05:31 PM
crispy's Avatar
you can go one inch wider tires than stock tires on stock rims right?
Old Nov 29, 2003 | 09:17 PM
BigScary's Avatar
I did
Old Nov 29, 2003 | 11:41 PM
fsu174u's Avatar
I'll give you a little (and cheaper) trick that I learned from some of the good guys on this site. Flip that rear shock linkage. I did just that on my Rappy, and it brought the body and seat down a couple of inches. Love the feel of it even better now.
Hope this helps you out.
Remember to respect your fellow riders, and the trails you ride on out there. We've got to take care of ourselves and our trails before "they" shut it all down. Peace (and ride it like you stole it...lol) [img]i/expressions/face-icon-small-smile.gif[/img]
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
highwayman
Sep 19, 2015 12:59 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
