99 Trailblazer: a few problems....
Old Nov 29, 2003 | 08:07 PM
Dyeform00's Avatar
Default 99 Trailblazer: a few problems....
Wow long time since I've been on these boards..... Well, my 99 trailblazer has a few problems.
1. The electric start does not work. When I press it all I hear is a loud click. If I hold it down for about 10-15 seconds i hear a small rumble, but it never starts. Whats going on?
2. The front bumper thing (stock oem) is really messed up on mine and it definitely needs replacing. Anyone know of any good inexpensive aftermarket ones that will look good?
3. I can't seem to find a winch mount kit anywhere for trailblazers. Any suggestions??
Thanks in advance for any info!!
Old Nov 29, 2003 | 08:37 PM
2manytoys's Avatar
Ok for the first thing the starter may have went bad due to water. There is a small drain plug in the bottom of the starter for this reason. It must be drained if you have gone through some deep water. If it is not drained then the contacts in the starter corrode and go bad.
Second DG makes aftermarket bumper for about $100. They look awsome too. Or Polaris makes a pretty cool looking bumper but is around $200.
And last there is no winch mount for a trailblazer but 1 can be made easily. I have seen winches on them.
Old Nov 29, 2003 | 08:44 PM
Dyeform00's Avatar
Alright... Having trouble locating my manual. Could someone provide me a link with a pic or tell me where the starter is?
Old Nov 29, 2003 | 08:46 PM
2manytoys's Avatar
It is on the very bottom of the quad on the left side just above the skid plate. Take the plate off and you will see it.
Old Nov 29, 2003 | 08:48 PM
quadwrench's Avatar
Sounds like your starter stopped starting.
An easy check is to take a DC test light, clip the ground to ground, place the probe nut under the rubber wire cap on the starter, and try to start it.
1.If the light comes on, your starter is defective - maybe just needs brushes, or could need a rebuild (as long as the armature windings are not defect). Could be cheaper to just pick up a new starter off Ebay if you are not mechanically inclined.
2. If the light does not come on, then there is a problem with the solenoid or cable from solenoid to starter.
Old Nov 29, 2003 | 08:50 PM
Dyeform00's Avatar
Ok haven't gone to pull that plug yet.....
Quadwrench, If I touch those two wires behind the battery when I start it, I can feel them jolting (with the wire cover stuff etc..). The click comes from there.
Old Nov 29, 2003 | 08:55 PM
quadwrench's Avatar
Thats the solenoid - the click is the internal contacts coming together as power is applied to start. Most problems are with the starter, but I have seen solenoids with burned contacts that don't let battery voltage get through to the starter - that's the reason for testing for voltage at the starter first - process of elemination by starting at most probable cause.
Old Nov 29, 2003 | 08:57 PM
TrailBlazerguy250's Avatar
Their is a winch mount kit for trailblazers. Their $500 and comes w/ a 2500lb winch. I checked it out at my local Polaris dealer.
Old Nov 29, 2003 | 09:00 PM
Dyeform00's Avatar
Quadwrench, so its the contacts that are burnt and thats why it won't start?? Is that something I can fix myself or should I take it to the local Polaris dealer?
Will this fit my trailblazer? http://rockymountainatv.com/wc.dll?w...rs~555008~~~~0
Old Nov 29, 2003 | 09:07 PM
2manytoys's Avatar
Dennis kirk and rocky mountain both carry DG bumpers for the trailblazer.
