Warrior valve adjustment
Old Dec 1, 2003 | 02:23 AM
Trasher's Avatar
Default Warrior valve adjustment
Does anyone know what the valve adjustment specs are and how to adjust the cam chain?
Old Dec 1, 2003 | 06:19 PM
Crotts's Avatar
Intake= .06-.07mm
Exhaust= .16-.20mm
What do you mean by "adjust the cam chain"? Do you mean adjust the tension of it or the cam timing?
Old Dec 1, 2003 | 08:50 PM
Trasher's Avatar
Yes, I mean the cam chain adjustment. Shouldn't that be done before the valves?
Thanks for the reply. So many people are collectively looking for a little help out here and it seems that not many posts are replied to.
Old Dec 1, 2003 | 08:51 PM
Trasher's Avatar
Also, the adjustment should be done when cold???
Old Dec 1, 2003 | 09:01 PM
warriorgod's Avatar
Yes they should be adjusted when the engine is cold.
Old Dec 1, 2003 | 09:03 PM
MOJAVE02's Avatar
let the valves set and get cool before checking lash specs. and there is no way to adjust the chain, it is a self tightning tensioner so not adjustable. if you mean you want to adjust the cam timing then lossen the tension bolts and remove the tensioner and adjust your b@lls off. i have done a few timing advances and retarding setups on these cams but there really isnt all that much to be gained.
Old Dec 1, 2003 | 09:12 PM
Crotts's Avatar
if there is slack in your cam chain that means that it is time to but a new one, yours is stretched to far. To check for this on the cam chain tensioner first remove the center bolt then take out the two bolts that hold the tensioner in. Then check and see if the plunger is fully extended, if it is it's time for a new chain.
Old Dec 1, 2003 | 09:23 PM
Trasher's Avatar
Thanks so much!!
Reactant
Mar 30, 2022 02:08 AM
donintennessee
Jan 8, 2021 12:40 PM
STLyamwar
Jul 25, 2020 04:44 AM
Hankey Pankey
May 1, 2018 01:33 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
