can I JBweld this mag cover?? (pics)
Old Dec 1, 2003 | 05:58 PM
danbleh230's Avatar
Default can I JBweld this mag cover?? (pics)
i bought a 230 quadsport, and i cant drive it until the mag cover is repaired.
the price is too high, something like 120$ canadian.
i though that i could jbweld it, i would like to know your opinions about if it is possible or not to jbweld it.
thanks
heres the pics:
http://cf.f2.pg.photos.yahoo.com/ph/.../cover+magneto
Old Dec 1, 2003 | 06:21 PM
Vinson581's Avatar
ouch, i would have to say .... no probley. jb is ok when you have a nic or something. i have a spare engine, that i have been selling parts to people if the need. i have that side cover, if you need one let me know...
Old Dec 1, 2003 | 06:53 PM
danbleh230's Avatar
how much would you sell it to me?
i live in Canada.
Old Dec 1, 2003 | 08:23 PM
Vinson581's Avatar
i got to make sure i do not need it. but how much were you thinking in U.S dollars? i can convert can. if nessacary
Old Dec 1, 2003 | 11:20 PM
danbleh230's Avatar
someone wanted to sell me his for 10$ canadian but i dont know if it is broken or not.
Old Dec 1, 2003 | 11:40 PM
robnhouston's Avatar
Actually I'd give it a try. What do you have to loose. Bevel the cracks with a grinder to give the jb weld a bit more surface to stick to. JB weld the inside and out, file down the part where the gasket sits.
But if you lose another chain you'll be doing it over again. Keep tabs on the chain.
If they still magnaflux these things you could try that. Cost a bit more than JB weld.
You might find some of these parts on Ebay.
Good Luck,
Rob
On edit..... Looks like a piece is missing? True? If so fab a metal piece to fill in the hole then JB Weld around it. Looks like there is no load on the area. Use extra gasket sealer and don't tighten the broken piece case bolt real tight. Might work for a long while or until you can find a replacement.
Old Dec 1, 2003 | 11:50 PM
TomM's Avatar
I had mine welded for 40$ but it was not quite as bad as that. The damage was similar but the piece was still attached so they just welded the cracks and built the bolt hole back up.
Old Dec 2, 2003 | 09:29 AM
Flynbryan's Avatar
No go. As soon as you place any torque on the that bolt hole its going to put too much strain on the union. I tried it already on a water pump cover once before. Just look for a used one. Used parts for the older quads seem to be every where. Especially on E-bay.
Old Dec 2, 2003 | 11:00 AM
tom18801's Avatar
oh thats an easy fix just sand the broken edges and smear jb weld all over it it will work
Old Dec 2, 2003 | 02:05 PM
DaveRS575's Avatar
I would say no, I'd agree that as soon as you crank down on that bolt it will strain the union and just break right off. JB weld is great stuff, but not that great IMHO.
I'd also agree that you can find this part on e-bay cheap. Check it out, just search on "quadsport" or "LT230" you'll see at least 2 or three for sale every week. It's aparently a common breakage item for the quadsport and quadrunner. Especially when you throw a chain. I'm considering picking one up just to have as a spare. You should be able to get one for under $40 bucks US (about $52 Canadian).
