removing noise baffle z400
I just rejetted my z400 and drilled out the pea shooter, and now I am in the process of removing the noise baffle but I can't seem to get it off the snorkle tube. How did you other guys get it off?
thanks,
chuck
thanks,
chuck
If your talking about the noise baffle over the snorkel intake tube, it adds power, if you jet for it. It's true if you remove it and don't jet it will run worse because the motor is getting more air so it also needs more fuel. If you have a slip on and didn't do any airbox mods and rejetting then your really missing out on some cheap power.
