Yamaha warrior help
Old Dec 4, 2003 | 11:25 PM
porto's Avatar
Default Yamaha warrior help
What is the name of the part where the exhaust header come out of the cylinder head. I need a new one. My bolt broke up in the engine.
Old Dec 5, 2003 | 12:45 AM
Crotts's Avatar
I think you are talking about the studs. They are removable and you can buy new ones.
Old Dec 5, 2003 | 12:58 AM
porto's Avatar
Yea i know that those are there. I broke the one off in the engine and i was wondering how to get it out and what the name of it is where the bolts are so i can buy a new one.
Old Dec 5, 2003 | 01:14 AM
trailride's Avatar
drill and tap
Old Dec 5, 2003 | 01:26 AM
JakalWarrior's Avatar
EZ out. Gonna have to have the head off probably to do it right unless its right close to the surface.
Old Dec 5, 2003 | 01:37 AM
porto's Avatar
The bolt is already broken off in the head. I tried to tap it out. But it didnt work. Do i need to buy a new head or is the a couple of certain parts that i can take off and replace. If so what are the names of the parts so i can look them up.
Old Dec 5, 2003 | 01:47 AM
just keep trying to tap it out and if all else fails put in a helicoil or timesert, maybe even tap it for a bigger stud.
Old Dec 5, 2003 | 01:51 AM
Crotts's Avatar
The studs go directly into the head
Old Dec 5, 2003 | 02:02 AM
porto's Avatar
If i take it to a atv repair place how much will it cost to have it heat coiled?
Old Dec 5, 2003 | 02:10 AM
Depends on if they have to take the head off or not. If they do it would save a good bit of money if you took it off ahead of time. Its not something thats hard to do though. You need a set of taps and a helicoil kit to fit the stud. If your good with a tap im sure it can more than likely be done with the head on.
