Pipe Questions
Old Dec 8, 2003 | 08:30 PM
Juice's Avatar
Default Pipe Questions
What’s the difference between a full pipe and just the exhaust? Is there a performance difference if you don’t go full? Is it worth the extra money?
Where does a silencer play into things?
Are there any good web sites that can explain differences between them? White bros seems to have 10 different pipes but there site doesn’t tell me much.
Old Dec 8, 2003 | 08:52 PM
AlphaRaptor660R's Avatar
Your full exhaust system consists of the header pipe and the silencer(muffler). Where as with just the silencer you'll be using your stock head pipe. On a stock quad, you won't notice much of a difference between using the full system or just the slip-on. Its not until you start modding your engine and spending some moolah that you'll notice differences between the 2. The full system is the best bet with a modded engine because the aftermarket header pipes usually have a larger diameter allowing more exhaust gas to flow out...
If your planning on keeping your engine stock, I'd say save yourself the money and just go with the slip-on. But if you plan on doing some engine work later, I'd say go with the full system. It shouldn't hurt your performance either way.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
bvolks
Sep 13, 2015 12:57 PM
Bigtwin700
Sep 9, 2015 09:32 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Brandon400
Sep 5, 2015 08:44 PM
