When is your stock carb no longer enough?
Old Dec 10, 2003 | 09:53 PM
n2atvs's Avatar
Default When is your stock carb no longer enough?
I have a 250x with a 12:1 piston,Web Cams #254 cam,full Supertrapp IDS exhaust and a K&N filter with no airbox lid.I am currently running the stock carb with the needle raised 1 notch and a 130 main jet.It really flattens out at high rpm's.Is it possible that my stock carb is not letting my engine reach it's full potential?Do you think a stock 400ex carb would be a good upgrade for it?
Old Dec 11, 2003 | 09:38 PM
n2atvs's Avatar
Anyone have any input on this?
Old Dec 11, 2003 | 10:13 PM
Yellow650Rincon's Avatar
Yes, if it is flattening out and loosing ***** on the top end a bigger carburetor will help. Does the 250x have the same sized carburetor as the 300ex? If not, what size is it?
Old Dec 12, 2003 | 10:12 PM
n2atvs's Avatar
Yes,it has the same carb as a 300ex.
Old Dec 12, 2003 | 10:51 PM
You could probably try it out. There are probably plenty of 400ex carbs laying around, so I wouldn't expect them to be expensive. Maybe someone else here has some more experience on this?
Old Dec 13, 2003 | 03:15 PM
n2atvs's Avatar
I think I am going to try the 400ex carb.I have seen several on Ebay pretty cheap.Thanks for your replies.
Old Dec 13, 2003 | 03:29 PM
manual's Avatar
acuttly i think there is a differnce in the 300ex and the 250x carbs, the 300ex has a accelerator pump and 32mm, and the 250x is a 34
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
