Tip For Adjusting Chain Tension
Old Dec 12, 2003 | 02:48 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default Tip For Adjusting Chain Tension
When adjusting you chain tension on a Honda, (like the 400EX, 300EX, 250R) don't even try to use the procedure they outline in the owners manual. They have you placing the hex wrench (that they supply for loosening the nuts) in the slots on the adjuster ring and prying on that to turn the adjuster. It works poorly, and will eventually hack up the slots on the adjuster.
I just use a large MotionPro shock preload adjustment spanner. The wrench is huge, and provides lots of leverage for large or fine adjustments. Works great!
Old Dec 12, 2003 | 03:19 PM
garyc660R's Avatar
How about another one.....if you overtighten your chain your suspension will stretch the chain as it works through it's cycle and lead too a shorter chain life. Always run a good chain lube.
Firefighter400
Oct 8, 2022 06:38 PM
bvolks
Dec 26, 2015 08:43 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
