11 :1 &stage 1 cam
Old Dec 15, 2003 | 05:03 PM
trisrik's Avatar
Default 11 :1 &stage 1 cam
just put 11:1 & stage 1 cam in the raptor while putting the 02 tranny in. also have white bros. e series slip on. and pro flow filter. what kind of hp. should i get out of this setup. and what would be the best front sprocet size.
Old Dec 15, 2003 | 06:08 PM
BigScary's Avatar
I ran that exact setup for about 2 months..........but when I put tha full system on (Sparks x-6) after that first month.......good gosh did that thing wake up.........TONS more mid and top power.........
Old Dec 15, 2003 | 06:23 PM
trisrik's Avatar
thanks for the info. next will be a full system
Old Dec 15, 2003 | 11:51 PM
eRAPTOID's Avatar
Get a good pipe and let it exhale, that's an important part of "breathing" too![img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 16, 2003 | 01:46 AM
Yamaha660R's Avatar
www.albaaction.com
The Alba pipe will really open that rappy up.
That looks like a good setup...but I'm pretty sure I'm going with....
Stage 2 Cam
12:1 Piston(unless it requires race gas, then 11:1)
Valve Springs
Port and Polish
Old Dec 16, 2003 | 08:40 PM
wshrdskin's Avatar
All dynos are different but, when I had the 11:1 stock bore and stage 1 cam with my current Alba pipe and jetting/no lid it made 53 hp on the dyno I used. You'll be happy with your improvements. My Raptor that day was useing 12/41 gearing. The dyno people put on 18" hoosiers for the test.
Dyno
PS, that same dyno, that same day dynoed a 2 hour old stock raptor at 30 hp.
Old Dec 16, 2003 | 09:08 PM
Yamaha660R's Avatar
I figure that would be right for a rappy that was just built and hadn't been broke in, or had the valves adjusted or anything. Rappys definetly need to have pipes to wake them up. I had my stock rappy after I got rid of the other one for 3 days before I put the alba pipe and all that stuff on the LE. I couldn't take it after having the old rappy with the pipe and stuff.
And that is a good power number. I wonder what a 12:1 stage 2, port polish would dyno with the alba pipe???
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
Backwoods_badass
Aug 28, 2015 12:35 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
Huntingdeer
Aug 23, 2015 12:06 AM
