float problems
Old Jun 22, 2000 | 10:32 PM
decoyrth's Avatar
I have a keihin carburetor (pwk 39mm) and I know that the floats are supposed to be 16 mm from the base of the carburetor, but where do you measure to on the floats. (front, middle point, or back)
Is it importnat to for it to be able to depress the spring loaded pin???
thanks for the help.
Old Jun 23, 2000 | 03:31 AM
hot_shoe_cv's Avatar
I don't have the specs for the Keihin, but on a Mikuni the float level is measured from the top surface of the float chamber, with gasket removed, to the top of the float. I would think the Keihin would be measured the same way,.
I don't understand your question re float valve, but the tang should rest on the valve but should not depress it at all
skinnyr6
Aug 25, 2023 02:18 AM
slowgsxr97
Mar 18, 2022 03:40 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
