300ex been down for 4 months
my 300ex has been down for 4 months i am getting inconcistent spark out of the coil. sometimes it will spark then it won't (not enough to crank the bike). i installed a new coil still no fire, so now i have taken casing over altenator off and i have just order a new pulse genorator sensor, i am hoping this will fix it but i am not sure. i wonder if it could be a bad cdi box? does anyone know how much a cdi box will run me?
any ideas or help is appreciated
This summer, I the same kind of problem. I ordered the whole CDI off ebay for 135$
Wiring Harness
-Coil
-CDI BOX
-INHIBITOR UNIT. REVERSE
-Solenoid
-Starter
It was only expensive because of the starter. And like cluby said, check your switch behind the little panel of the bottom of the (I think) left engine case. it can cause a lot of trouble.
Wiring Harness
-Coil
-CDI BOX
-Solenoid
-Starter
well i have checked all the wiring and i have put a test light on the neutral switch on the cdi and when i put it in reverse i get signal from it, and i have changed the coil and i still get no spark , so i have ordered a new pulse generator and i'm waiting on it to get here hopefully that will fix it, if not i guess my only other option is to just order a new cdi
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
