300ex been down for 4 months
Old Dec 17, 2003 | 11:30 PM
accorracer's Avatar
Default 300ex been down for 4 months
my 300ex has been down for 4 months i am getting inconcistent spark out of the coil. sometimes it will spark then it won't (not enough to crank the bike). i installed a new coil still no fire, so now i have taken casing over altenator off and i have just order a new pulse genorator sensor, i am hoping this will fix it but i am not sure. i wonder if it could be a bad cdi box? does anyone know how much a cdi box will run me?
any ideas or help is appreciated
Old Dec 18, 2003 | 12:03 AM
cluby's Avatar
well your reverse wire isn;t grounding out some where cause I have had that problem which will create the same kinda problem. Or have you checked the spark plug cap.
Old Dec 20, 2003 | 04:37 PM
TheQuadSport230's Avatar
This summer, I the same kind of problem. I ordered the whole CDI off ebay for 135$
Wiring Harness
-Coil
-CDI BOX
-INHIBITOR UNIT. REVERSE
-Solenoid
-Starter
It was only expensive because of the starter. And like cluby said, check your switch behind the little panel of the bottom of the (I think) left engine case. it can cause a lot of trouble.
Old Dec 20, 2003 | 05:03 PM
BADBRONCO's Avatar
Check all wire connections and clean them up.You'd be surprised what gets dirty and can come loose.
Old Dec 20, 2003 | 08:56 PM
accorracer's Avatar
well i have checked all the wiring and i have put a test light on the neutral switch on the cdi and when i put it in reverse i get signal from it, and i have changed the coil and i still get no spark , so i have ordered a new pulse generator and i'm waiting on it to get here hopefully that will fix it, if not i guess my only other option is to just order a new cdi
Old Dec 20, 2003 | 09:00 PM
WISTECH's Avatar
check your pm's
Ahtatu
Sep 28, 2015 12:14 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
