Engine Lugging
Old Dec 20, 2003 | 04:28 PM
TheQuadSport230's Avatar
Default Engine Lugging
I read on another post that lugging (being in a too high gear) an engine too bad can break something. How is this possible?. Thanks
Old Dec 20, 2003 | 04:49 PM
01redrecon's Avatar
Not sure on how much it will break but it will wear your clutch out much faster then if you were to ride in the right gear.
Old Dec 20, 2003 | 06:04 PM
hondabuster's Avatar
Lugging an engine means putting the engine under an extremely stressful load. A common way to lug an engine is to operate it at an extremely low rpm while the transmission is in a higher gear (for instance, leaving the transmission in fourth gear when it should be in second or third where engine speed is better matched to transmission speed). Lugging causes extreme stress between the rear thrust faces of each piston and the cylinder walls. Small bits of piston skirt can break away causing the rear surface to scuff. The best prevention for lugging an engine (either old or new) is to downshift to a lower gear where the engine runs more freely, and the transmission assists the engine in delivering peak power to the rear wheels.
Old Dec 21, 2003 | 11:07 AM
dzzy's Avatar
Yes it can frag your clutch if severe enough. More likely just burn the plates tho.
Old Dec 21, 2003 | 12:47 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The term "lugging" doesn't necessarily always have a bad connotation. For instance, the motor in the 400EX or the Warrior will lug down better than the Z400, which likes to rev. The Rancher motor, will REALLY lug down. What lugging down means in this sense is that the motor will perform well at low rpm, has good low end torque, and won't stall easily.
Old Dec 21, 2003 | 06:42 PM
I think I've got my answers.... Thanks everybody [img]i/expressions/face-icon-small-happy.gif[/img]
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
