Vinson Engine Not Running Right
Does a Vinson have a fuel filter? A friend of mine has a 2002 and it isn't running right. When you get to about 25 mph the engine starts cutting out. We cleaned the air filter and put in a new spark plug and it still dosen't run right. Could it be water in the gas? If so, is it safe to ust Heet or some other gas treatment to get the water out?
Thanks
Thanks
Has the temperature dropped enough in your area to make jetting a factor?
First, I would disconnect the fuel line, and drain the fuel completely, and fill the tank with fresh gas. Also, maybe a piece of dirt got into the carb.
Thanks for the help.
Don't use heet. I had some water in my fuel and asked my dealer about using heet and I was told it could actually damage one of the parts in the carburator. A vacum slide in the carb or something. It's not a cheap part either so you may want to check into it before using fuel additives. I never thought heet could be bad but I'll take my dealers word for it.
take the tank off, and drain the fuel, that will make a difference. i have had my carb off, all you have to do is take the black piece of plastic off around the tank, and then the screw that goes to the rubber boot on the carb, be forwarned, DO NOT TILT THE CARB ON THE BIKE, as gas will flow out.
Thanks for all of the replys. I'll probally go and work on it again later today. I'll let you know what fixes it (hopefully). [img]i/expressions/face-icon-small-blush.gif[/img])
SOLOLUCKY
Oct 4, 2024 09:09 PM
Hankey Pankey
26
Oct 18, 2020 03:50 PM
