Vinson Engine Not Running Right
Old Dec 20, 2003 | 11:10 PM
Rifleman3006's Avatar
Default Vinson Engine Not Running Right
Does a Vinson have a fuel filter? A friend of mine has a 2002 and it isn't running right. When you get to about 25 mph the engine starts cutting out. We cleaned the air filter and put in a new spark plug and it still dosen't run right. Could it be water in the gas? If so, is it safe to ust Heet or some other gas treatment to get the water out?
Thanks
Old Dec 20, 2003 | 11:53 PM
Quadfather's Avatar
Has the temperature dropped enough in your area to make jetting a factor?
First, I would disconnect the fuel line, and drain the fuel completely, and fill the tank with fresh gas. Also, maybe a piece of dirt got into the carb.
Old Dec 21, 2003 | 12:52 AM
Polaris500HO4x4's Avatar
yes heet is good to use it keeps your fuel lines from freezing up too
Old Dec 21, 2003 | 02:12 AM
No, It's been running fine all fall, and it was actually warmer today than it has been for a while.
We used a siphon hose and got most of the gas out, then refilled it with known good gas. If water is the problem, we probally just didn't get it all out.
I hope it isn't dirt, because it dosen't look easy to get the carb off.
Thanks for the help.
Old Dec 21, 2003 | 03:57 AM
HoosierVinson's Avatar
Don't use heet. I had some water in my fuel and asked my dealer about using heet and I was told it could actually damage one of the parts in the carburator. A vacum slide in the carb or something. It's not a cheap part either so you may want to check into it before using fuel additives. I never thought heet could be bad but I'll take my dealers word for it.
Old Dec 21, 2003 | 09:43 AM
macgiver's Avatar
the fuel pickup in the tank usualy has a screen type filter around it. i have read that some people have had problems with this. drain the tank and remove the petcock, to inspect it.
Old Dec 21, 2003 | 10:40 AM
Vinson581's Avatar
take the tank off, and drain the fuel, that will make a difference. i have had my carb off, all you have to do is take the black piece of plastic off around the tank, and then the screw that goes to the rubber boot on the carb, be forwarned, DO NOT TILT THE CARB ON THE BIKE, as gas will flow out.
Old Dec 21, 2003 | 02:08 PM
Thanks for all of the replys. I'll probally go and work on it again later today. I'll let you know what fixes it (hopefully). [img]i/expressions/face-icon-small-blush.gif[/img])
SOLOLUCKY
Oct 4, 2024 09:09 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
Hankey Pankey
26
Oct 18, 2020 03:50 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
scaldwellk
Jun 19, 2015 05:08 PM
