400 EX Mods
Old Dec 27, 2003 | 12:41 AM
Banshee18267's Avatar
Default 400 EX Mods
I have a 1999 400 EX. It puffs a bit a blue smoke when first started. I am guessing this is a ring problem. I would like to put a higher compression piston in along with a cam. Would anybody have some good suggestions:
What pistion type?
What compression?
What cam?
The bike has been piped, jetted and air box modified.
Thanks
Old Dec 27, 2003 | 12:59 AM
pimp250r's Avatar
Default 400 EX Mods
im not a 400ex guy but my guess would be:
a 11:1 piston...otherwise you'll have to run race gas ot atleast a mix
im not sure about the cam...but for a piston...maybe a pro lite piston
anyone around to help this guy out?
Old Dec 27, 2003 | 02:54 AM
420EX's Avatar
Default 400 EX Mods
i run a Wiseco 11:1 piston with a hotcam stage 2 cam and porting, i heard bad things about wiseco's compression ratings tho i have no complaints. from what i have heard, JE pistons are the best. as for the cam, i have heard web cams are the best, the hotcams are cheaper tho. thats what i un
Old Dec 27, 2003 | 03:00 AM
cals400ex's Avatar
Default 400 EX Mods
i would go with a je or ross 10.8:1 compression piston and a hotcam. if your looking for a high revving bike, go with stage 2. if you are worried about lowend power go with stage 1. the web cams require hardened rockers. you can't run hardened rockers with a regrind like the hotcams. by the way, if your puffing a little smoke on start up, i would also replace the valve seals.
Old Dec 27, 2003 | 09:20 AM
Default 400 EX Mods
Thanks. I would rather have the bike be quick on short bursts. We ride mostly in tight areas except for when we travel out to Little Sahara. I would like to see it be responsive to the quick punch of the throttle. Would changing the carb be worth the investment?
David
Old Dec 27, 2003 | 10:38 AM
'98RECON's Avatar
Default 400 EX Mods
If you only notice it when the 400 is first started then it is probably the valve seals. When they go bad they let a little oil seep down from head, not enough to notice unless the 4-wheeler has not been running and enough oil has gathered in the cylinder.
Old Dec 27, 2003 | 02:13 PM
cals400ex's Avatar
Default 400 EX Mods
yeah, i was thinking it was probally the valve seals too. go with stage 1 if you just want short bursts of speed.
Old Dec 27, 2003 | 02:15 PM
cals400ex's Avatar
Default 400 EX Mods
with a larger carb it is possible to lose a little power until you get the rpm's up a bit. however, you might be satisfied with a stock carb bored out.
Old Dec 27, 2003 | 09:06 PM
DaSandBomb's Avatar
Default 400 EX Mods
mine was smoking then i changed the oil twice with 20-50 insted of 10-40 now it doesn't smoke at all, so try 20-50 honda oil
kc
Old Dec 28, 2003 | 08:52 AM
Default 400 EX Mods
Thanks again to everyone for the advise. I will try the oil remedy if I don't crack into the engine.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
