I hate clutches Part 2
Old Dec 29, 2003 | 11:41 AM
BillDS650's Avatar
Default I hate clutches Part 2
Went to install my clutch this week heated up my old pressure plate and removed the bearing. Heated up new plate and press in bearing now it hangs when turning, reheated palate removed bearing have too order new one. I will let dealer replace bearing.
Old Dec 29, 2003 | 02:15 PM
IGotA650X's Avatar
you supposed to heat those. couldnt you just ride around witht he clutch pulled half way in for about and hour. Bet it would be roasty toasty by then. : )
I understand your pain. Thats why i got away from my old two stroke too much slipping of the clutch, was replacing it like every six months.
Old Dec 29, 2003 | 08:51 PM
Hightower's Avatar
it can be a pain, I know, very tricky sometimes.
the trick is to heat up the surface surrounding the bearing quickly with torch, and then get the bearing out before the heat gets a chance to dissipate into the bearing and expand it as well. otherwise they're both expanded and its still tight. too much heat and the ball cage inside the bearing is toast.
on installation, heat the plate to 200 (in oven), freeze the bearing, and seat with appropriate size tool/socket. pounding on inner race will damage bearing, must use tool that fits outer race.
ghost civic
Jan 15, 2020 07:43 AM
txpedsrt1
Feb 3, 2017 08:07 PM
ghost civic
Jul 15, 2015 10:48 PM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
