no clue what it is......
Old Dec 30, 2003 | 11:46 PM
BT250racer's Avatar
Default no clue what it is......
today when i went ot grease up the fittings i seen the motor above the head pipe had all kind of black oil or somthing all over the front. do any of you guys know what it is??? whats causing it?? and is it ok to still ride??
1999 250 trail blazer
k&n filter DG exhaust
titan 489 xts on the back
maxxis razors on the front
full skid plate,bash gaurd
rebuilt trans,D.I.D chain
pro amor belt,scott grips
the newer model tie rod ends
12 t front 36 t back sprokets
neon shifter ****, pro burner lights
Old Dec 31, 2003 | 12:26 AM
BT250racer's Avatar
could it be somthin a wrong with the head gasket and its leaking oil through there
Old Dec 31, 2003 | 12:29 AM
trailrider500's Avatar
Was it on top of the head or were the head meets the jug? If it was on top it could be that the PVT vent blows air on the head and it might be debris from the belt wearing...
Old Dec 31, 2003 | 12:31 AM
BT250racer's Avatar
it was where the head meets the jug
Old Dec 31, 2003 | 12:34 AM
JEFF10049's Avatar
Check your exhaust flange gasket mine was leaking and was blowing carbon on the area above it I did not even hear a exhaust leak found it when I put my pipe on.
2003 TB250 RcR stage 1
milled head
Jeff
Old Dec 31, 2003 | 12:38 AM
BT250racer's Avatar
i just put this DG exhaust i bought from a friend for 50 bucks until i decide on which pipe i want to get so im going to check what you said and i also noticed like when im out riding and start to slow down and when im about to a stop i hear like air swooshing in that area could that be the exhaust leak??
Old Dec 31, 2003 | 12:48 AM
JEFF10049's Avatar
Not sure what it would sound like but on mine the nuts were tight and the gasket good the flange was bent my exhaust came with a new flange if yours dose not check it with a straight edge. you can resurface it with a file or belt sander if it's not real bad. They do blow alot of oil and black stuff when warming up if not sealed.
Jeff
Old Dec 31, 2003 | 12:49 AM
Thats what it sounds like to me, Most 2 strokes will run really crappy with a exhaust leak they need their back pressure.... Check it out feel around you might feel the exhaust leaking....
And do as jeff said he right....
Old Dec 31, 2003 | 12:51 AM
BT250racer's Avatar
thanks jeff ill check that out
1ArmBandit
55
Oct 14, 2015 09:03 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
quickwhips
Sep 2, 2015 06:53 AM
Jordanl6112
Aug 3, 2015 10:19 PM
