bleeding brakes, need help!!
Old Jan 1, 2004 | 06:09 PM
NITROMAN500's Avatar
Default bleeding brakes, need help!!
Im trying to bleed the brakes on my scrambler 500 and i'm finding it very difficult. It seems as though no matter how much time i spend bleeding them, they still are weak. Also, when the brakes do work, the left front wheel will stop but the right front wheel recieves no braking power. What should i do, any help wpuld be greatly appreciated.
Old Jan 1, 2004 | 06:26 PM
trailrider500's Avatar
Sounds like you caliper on the right side might have dirt or some other debris in it causing it to stick.. My rear brake don't work to good either... Try cleaning your calipers and bleeding the entire brake system..
Old Jan 1, 2004 | 06:27 PM
You may also have dirt in your brake lines, i would change all the brake fluid as well...
Also are you sure your bleeding them the right way?
Old Jan 1, 2004 | 08:57 PM
OffRder15's Avatar
You might also want to check the adjuster screw on your front calipers. Turn the adjuster screw until the pad contacts the disk, then back off 1/2 turn.
Old Jan 1, 2004 | 11:30 PM
BADASSS250RIDER's Avatar
Your brake pads might be worn too check those out.....
Old Jan 2, 2004 | 10:36 AM
harescrambler's Avatar
how are you bleeding them the rear first don't recall which bleeder on rear is hand or foot 2nd right front last left front make sure that when you crack the bleeder its all fluid no air
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
