auto-clutches
Old Jan 1, 2004 | 08:28 PM
GTFZ250's Avatar
Default auto-clutches
Do centrifical auto-clutches actuate only when the rpms shft the weight of the motor and some ball bearings or some $hit like that release the clutch? I dont really know how exactly they work, could you fill me in? I have to know how things work to be able to use them properly. Please respond...[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 1, 2004 | 11:23 PM
kybabyn's Avatar
well it seems that when you pull the shift leaver up it pulls the clutch it becausae you can rev it as long as you hold it up and not go anywhere. and when you drop it it engages. thats why the shifter lever feels totaly different on autoclutches. you also have to pull them up way higher if you notice.
Old Jan 2, 2004 | 12:07 AM
peteyz24's Avatar
yes the shift lever disengages the clutch, but the clutch is also disengaged under a certain rpm and engages by itself at a certain rpm, so you can leave the machine idle in gear and it will not move, or shouldnt
Old Jan 2, 2004 | 01:55 AM
hondabuster's Avatar
auto clutch
See if this helps[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 2, 2004 | 09:29 AM
dzzy's Avatar
Most ATV's actually have two clutches. The centrifugal one is ONLY disengaged when the engine drops below a certain RPM. The manual clutch is what you use when you shift gears once you are moving and is the same wet type used on sport quads or motorcycles with a lever mounted on the handlebar. The only difference is it is actuated off the gear change pedal, rather than via a lever on the handlbars. That is why you can do what kybabyn describes.
Old Jan 2, 2004 | 09:37 AM
Vinson581's Avatar
i can sned you a pic if you need gtfz250, like said there is 2 clutches. one is for idleing a big "clutch bell" and then large shoes attached to sprngs, then at a rpm it ingages. and then you have the clutch basket, a series of plates and discs, that allows the quad to disengage the tranny. when the shift lever is in the up position it catches on the basket, ans pulles it in, then when you let go it releases it and ingages.
Old Jan 2, 2004 | 01:40 PM
GTFZ250's Avatar
so could I get aftermarket clutch basket for my Z250? Yes I would like a picture. And so it is posible to be able to put a lever on my handlebars to be able to actuate the clutch myself?
Old Jan 2, 2004 | 01:45 PM
Vinson581's Avatar
there is a clutch kit for the Z manual, search for it on the connection you should be able to come up with a place.
Old Jan 2, 2004 | 01:49 PM
GTFZ250's Avatar
k thanx alot man
Old Jan 2, 2004 | 03:20 PM
kybabyn's Avatar
oh ya forgot to mention the engauging at a certain rpm range. because if you put it in gear and turn up the idle it will want to or even start moving.
steve069
May 25, 2014 10:46 PM
RedGoblin
Feb 22, 2005 08:56 PM
SuzukiRyder22
Aug 5, 2003 01:44 PM
SuzukiRyder22
Jul 30, 2003 04:06 PM
