Sand tire pressure?
Old Jan 2, 2004 | 07:36 PM
Jerfinds's Avatar
Default Sand tire pressure?
What psi do you run in sand tires, extreme haulers to be exact for the best possible traction. I usually run about 5 psi in my holeshots but not sure about my haulers. Would lower pressure be better. I dont want to hurt the tires. What do you run?
Old Jan 2, 2004 | 07:39 PM
BlackHawk's Avatar
3 psi is very popular. I've heard some people going to 2.5 psi however I kinda like 3 psi since I don't want to risk the tires coming off of the bead. Right around 5 - 6 PSI is normal for dirt tires.
Old Jan 2, 2004 | 08:09 PM
Jerfinds's Avatar
Thanks BlackHawk, They are at 3psi now, so I'll just try that and go from there.
Old Jan 2, 2004 | 09:09 PM
SANDMAN430's Avatar
the air pressure depends on the sand,if it is real dry and fluffy 3 pounds is good. if the sand is wet go 5 or higher, some go as high as 10 psi.
Old Jan 2, 2004 | 09:19 PM
DSWOLF's Avatar
it all depends on the riding that you do but i would go whit 5psi.
Old Jan 3, 2004 | 12:57 AM
SpinCycle's Avatar
The lower tire pressures work well over the whoops..
Old Jan 3, 2004 | 01:39 PM
ironrod's Avatar
3-5 psi for the rear, 8-10 psi for the front.
Old Jan 3, 2004 | 09:06 PM
Squatcher's Avatar
ironrod do you run that high a pressure in your fronts at the dunes. Do you just drag or ride in the dunes? I can see that pressure in a drag. I almost killed myself this weekend at the dunes with 9psi in the front. (I had a bad gauge) went down to 5 or 6 psi and was alot better. 3-5 in the rear is just right I think aswell.
Old Jan 3, 2004 | 11:55 PM
busmechanic's Avatar
I like 4 in back 5 in front.
Old Jan 4, 2004 | 08:50 AM
ironrod's Avatar
I run that pressure in the front most of the time when I drag. You'll get at least 1-2 bike lengths out of that. For the trails, equal pressure around 5-7 psi all the way around is good. I do change my pressure a lot. I ended up with one of those Sears portable air tanks - I use it all the time!
Another note: I have really good shocks up front and I rely on them to do the work more than the tire.
Marky
