Floodrunner - - Question?
Old Jun 26, 2000 | 07:06 AM
Loyal's Avatar
This past weekend I started at the override button override modification. I found the lt purple wire and grey/white. Instead of cutting the wires I just made a "jumper" to go between the two terminals.
The Problem . . . the reverse limiter still cuts in. I look for the ever elusive grey\orange wire but could not find it. On my 96 Xplorer a red and a brown wire come from the speedo . . . no grey\orange. I reviewed the wiring diagram in the the manual. . . nothing. Can you explain where the grey\orange originates or where it ends, anthing to help me find the sucker.
While I was at I also hooked up a horn. A little cheezy but its a use for the button.
Old Jun 26, 2000 | 01:31 PM
Deej's Avatar
Loyal,
I think the root of the problem is that the wiring on the Polaris models changed drastically in '99. Previous models had a mechanical speedometer and had a wiring board under the hood where all wiring connections were made. In '99 the wiring board disappeared and a full wiring harness was used. The speedometer for '99 and up is an electronic model.
The wiring to your speedometer is simply for the light in the speedometer. The wiring to the new speedos is for the light as well as speed sensor.
Bottom line, I believe the instructions you are reading on Floodrunner's site cover conversion of the newer models only. You need to find someone who has done this to the older models.
DJ
Old Jun 26, 2000 | 03:24 PM
Loyal's Avatar
Deej,
You are correct, my Xplorer has a mechanical speedo and the wires are for the lights.
You know anyone who did it on an older Polaris??
Old Jun 26, 2000 | 05:19 PM
floodrunner's Avatar
I honestly wish I could help you Loyal but I don’t have a schematic for your bike and haven’t done a bypass on one of that vintage. The reason I credited the two other guys for their override plans is they figured them out, not me. I just took their ideas and ran a little farther with them. Sorry you’re having trouble, but I can’t answer your question.
Old Jun 26, 2000 | 07:33 PM
CHICKENman's Avatar
I check my manual for 96 magnum and 500sp they both have PUR - gr/w -GRN I don't know if that will help you all I can do. CM
Old Jun 27, 2000 | 06:54 AM
Loyal's Avatar
Hmmmm . . .
I guess I have a bit of figurin' to do. When a solution is found, I will post.
In the meantime, if anyone knows the answer PLEASE post.
Thanks all.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
