300ex sprockets
Old Jan 4, 2004 | 04:51 PM
300racer's Avatar
Default 300ex sprockets
do you guys think i should change my sprockets for acceleration over top speed .would it be worth losing the top speed,how much would i lose for each tooth up or down
Old Jan 4, 2004 | 04:56 PM
Eric250EX's Avatar
im pretty sure its:
more teeth=faster top end
les teeth=faster acceleration
dont know what the diff would be if u got a new sproket with like 1-3 more/lees teeth
Old Jan 4, 2004 | 05:08 PM
FarmStud's Avatar
Depends what you do. You could calculate your speed difference by dividing the teeth on the new sprocket by the number of teeth on the old sprocket. You could probly pull another tooth.
Old Jan 4, 2004 | 06:37 PM
300racer's Avatar
i want 1-3 less teeth on rear sprocket
Old Jan 4, 2004 | 07:32 PM
300exRiderJay's Avatar
I am pretty sure that 1 tooth bigger on the front is the same as 3 smaller on the back. Just saying that because it may be cheaper for a front sprocket then rear.
Old Jan 4, 2004 | 07:39 PM
300racer's Avatar
ok what will it do? like how much mph would it take off and how much more acceleration would it give im hoping to get sprockets real soon
Old Jan 5, 2004 | 07:04 PM
300racer's Avatar
what do you guys think
Old Jan 23, 2004 | 10:22 PM
GhostRiderNB's Avatar
Dudeman! Here's the xcoop on 300EX sprocket fixes...
Stock is 13 front and 38 rear with 22 inch tires right! ----------- About 55 miles an hour...
Change your gearing and tires to this and reach 65-70 depending if you are running a good aftermarket headpipe and sliencer...
Do a 14 Tooth Front Sprocket with a 36 rear sprocket and down your rear tire size to a 20 inch to regain some wheel torque and watch it go like a raped ape...
2002 300EX Yeller
White Bros E-series with Headpipe
Already ordered Parts
White Bros Aluminum Nerf Bars, Screen Front Bumper and Wide Rear Grab Bar
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
