dual carbs//where??
Old Jan 4, 2004 | 09:24 PM
outlaw105's Avatar
Default dual carbs//where??
what do you think of dual carbs on a stock bore/stroke motor? where is the best place to order them from? and if you got them, how do you like them????
Old Jan 4, 2004 | 09:27 PM
MOJAVE02's Avatar
what kind of machine is it?? you cant just put dual carbs on any machine
Old Jan 4, 2004 | 09:29 PM
outlaw105's Avatar
sorry, ds form... 03 ds650... talk to me..
Old Jan 4, 2004 | 09:49 PM
SANDMAN430's Avatar
probably to much carb unless you go 33mm -35mm
Old Jan 4, 2004 | 09:52 PM
MOJAVE02's Avatar
way to much carb for a stock motor. dont bother change the cam, pipe it, and put in a high comp piston first. duals are a waste of time
Old Jan 4, 2004 | 10:05 PM
ironrod's Avatar
I've seen duals run on a stock bike and I just don't think they are worth the extra money. That being said, If you go to larger valves and some head porting, then I think it's a good investment. When you consider a tuned TM45 is way under $400, and compare that two dual that are over $750, well, its hard to justify, and I doubt you'll end up with a huge difference in horsepower. My advice would be to get an inexpensive TM45, and use the money saved by putting that into cams or a CDI.
Marky
Old Jan 4, 2004 | 11:04 PM
outlaw105's Avatar
the bike is stock except for the carb mount air filter, ported intake, i did ,and the exhaust , i made out of stainless steel. 1 1/2 " primary to 1 7/8" mid, to a pro circuit t4... im about to order up some stuff and tear it down.. a 14.1:1 pistion, not sure on the cams yet,but i really want to spin this motor, the head will be completly ported, vortex cdi , and still not sure on the carbs.. what do you guys think and where can i get the parts at.. thanks...
Old Jan 5, 2004 | 10:36 PM
KMDuner's Avatar
I have duals on a stock bore and I think it runs pretty good.
Sep 30, 2015 01:37 AM
HondaR24
Jul 23, 2015 11:22 AM
hugemoth
Jun 4, 2015 02:56 AM
yamahagye
Mar 2, 2001 10:47 PM
