Scrambler Tranny Mod
Old Jan 5, 2004 | 08:12 AM
ProXPredator's Avatar
Default Scrambler Tranny Mod
I'm looking for some assistance. I plan to pick up a new Scrambler 500 - but I want to modify the tranny from the get go. I was told that a Sportsman 500 tranny would bolt right in. Then someone told me and older Polaris tranny would bolt right in. I don't want to do any modification to the frame if I don't have to, but I want the option of low/high range. I do a lot of plowing with mine current 400 Scrammy, but it tends to eat up at least one belt/winter. I want the high range and speed for all around riding - so getting a Sportman isn't an interest to me. Thanks all - Modquad, didn't you write an article on this topic a while back??
Old Jan 5, 2004 | 08:18 AM
fishslab's Avatar
It may work with an older SP500 tranny as long as the rear is not shaft drive. I've heard of two guys doing the swap with an Explorer 400 tranny. I think you need to run the same size tires and sprockets as the 400 for the 4x4 to work like it should. You may be able to just mess with the sprockets to get the right ratio. earlier swap thread
Old Jan 5, 2004 | 11:40 AM
modquad's Avatar
The mods I've done are the shifter removal (replacing w/ fabbed aluminum short lever), and the reverse gear removal. Sorry.
Old Jan 5, 2004 | 05:55 PM
That's what I heard, and Explorer. Thanks for the brain refresh!!
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
