Polaris Scrambler 50 No Spark
Old Sep 20, 2015 | 01:19 PM
Nosparkpolaris's Avatar
Default Polaris Scrambler 50 No Spark
Need help figuring out why the Polaris Scrambler 50 has no spark.... FYI, it sat for 3 years. Briefly, got the scrambler running, then it quit, no spark now. Also, a new battery was installed in the Scrambler. Any ideas?
Old Sep 20, 2015 | 04:21 PM
First I'd clean the flywheel area and pickup coil as these little 2 strokes sucked in a lot of dirt and mud. If it still doesn't have spark,disconnect the black wire from the cdi and see then if it has spark. If not,then a stator check would be next.
Red lead on a multi meter on the BLACK stator wire. Black meter lead on the white/red wire should be 450 ohms. Black lead to black/red wire,900 ohms,black lead to yellow/red wire, .05 ohms,black lead to white wire,0.6 ohms. Coil check should be coil tab to ground .3 ohms. Secondary(coil wire to coil tab) around 6k ohms.
Jmuddin284
Jan 19, 2026 07:16 AM
jettman
Jul 6, 2015 12:16 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
D-Hagz
Jul 4, 2015 02:19 AM
