RearSprocket for Trailblazer
Old Jun 26, 2000 | 07:39 PM
MEDSKER's Avatar
I have been considering putting a different sprocket on my Trailblazer for more low end, will this bring the front end up easier or not??? I did some rock climbing the other day and pulling the front end up quick would be helpful. Thanks
Old Jun 26, 2000 | 07:45 PM
go500's Avatar
Try putting a clutch kit on, it helps the trailblazer quite a bit. I tried a EPI kit, don't know about the others, good luck
2-2000 500 Scramblers
1-2000 400 Scrambler
Old Jun 26, 2000 | 07:58 PM
94DGblaster's Avatar
He already has the RCR kit. That includes a clutch kit.
I never had any trouble getting the front end up with my blazer with the RCR low-end.
You could drop your front down a tooth. You would get a lot more low-end. but you will lose top-end speed.
And you could always get a bigger carb.
Old Jun 26, 2000 | 08:06 PM
TheQuadfather's Avatar
The RcR kit has a different spring for the primary clutch. A real clutch kit, like one from HPD does wonders.
Old Jun 26, 2000 | 10:04 PM
talonhawk's Avatar
I just talked to the guys at Hotseat Perf.
They have an upgrade for their clutch kit.
Instead of the brown primary spring they suggest the new Pink spring. It has a higher engagement than their brown. I have their clutch kit in my TB and can pull the front end off the ground now.
Old Jun 27, 2000 | 12:22 PM
MEDSKER's Avatar
I can pull the front up now but it takes some room, I guess what I want is to nail it and have it come up quick for rocks and logs, I hate to say it but maybe I need somthing with a manual clutch, any ideas will be appreciated, will the clutch kits do what I need and what do they cost??
Old Jun 27, 2000 | 11:51 PM
talonhawk's Avatar
The Hotseat clutch is $159.95 and it comes with springs, weights and a helix. The hpd kit is $80 and it comes with springs and weights. Different spring combinations affect the way your bikes PVT engages and shifts out. You should contact them personally to find out which springs will give you what you need.
neo27ny
May 14, 2018 12:19 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
shewshew989
Jul 14, 2015 03:09 AM
