Need help with tach installation on scrambler 400
Old Jan 13, 2004 | 09:37 PM
flyinwhiteboy's Avatar
Default Need help with tach installation on scrambler 400
I bought a sunpro analog tach from autozone and hooked it up on my scrambler. I wired black to ground, red to a red/white wire that was hot with the ignition switch on, white to the lights and green to the yellow/red wire coming off the stator. I have the switch on the tach set to 4 cylinder. When I turn the key on the tach needle jumps to 0 but when I start the engine the tach doesn't move. Have I done something wrong??
Old Jan 14, 2004 | 09:18 PM
Anyone have any ideas? I believe this is the same tach that some of you have on your scramblers. I did play around with it and took the green wire off of the red/white wire and hooked it up to another wire coming off the stator. It was a yellow or yellow/brown wire and the tach started to read but it read 3500 rpm at idle. Any help at all would be appreciated.
Thanks
Old Jan 14, 2004 | 11:41 PM
Whitedog's Avatar
I had the same trouble hooking mine up this summer, I think my trouble was in the grounding. Ill look at it tomorow and if no one has answerd your question, ill try and help.
Old Jan 15, 2004 | 10:16 AM
ok thanks
Old Jan 15, 2004 | 02:06 PM
fishslab's Avatar
I know with my Polaris tach I had to specify 2 or 4 stroke when purchasing. Not sure if that may be a problem for you.
Old Jan 15, 2004 | 08:10 PM
Bubba297's Avatar
A regular tach will work with a single cyl 2-stroke. In the 4-cyl setting you have one cyl per cycle. It works out great. I did have the black to a good chassis ground, red to ign. on, white to the lights, and green either the yellow, or yellow/red. Now I see that you have both a 4-stroke and a 2-stroke Polaris. The tach will not work on a 4-stroke, those require a 6 pulse tach instead of the 2 pulse tach for the 2-strokes. In other words it must be made for a 4-stroke motor. Bubba
Old Jan 15, 2004 | 08:33 PM
The tach is on my 2 stroke 400 scrambler. I actually don't even have the 500 anymore. I sold it a few months ago
Old Jan 15, 2004 | 09:06 PM
Maddog419's Avatar
Thanks Guys:
What is the ppr on the scambler 400. Year 2002 and the wire that you can hook a tach to. Not the plug wire thanks.
later
ReconBayou
Oct 31, 2022 05:37 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
2many2ride
Sep 27, 2015 04:35 AM
