300ex Lonestar Axle Carrier???
Old Jun 27, 2000 | 07:42 PM
300exSTER's Avatar
My 94' 300ex's rear barings always get shot within about 4-5 weeks, so its about 50$ a shot. I am now going to buy an Lonestar Super Twin Axle Carrier, and i would like to know if this would be worth the purchase of 210.00$. I have spent about 150.00 on just barings in the last year and a half. Thanks, any information would be appreciated
Old Jun 27, 2000 | 07:44 PM
stevie's Avatar
Well in the long run that thing will pay for its self.
Old Jun 27, 2000 | 10:32 PM
hondatrx300ex's Avatar
every 4-5 weeks? that doesn't seem right. I think you have a problem.
Old Jun 27, 2000 | 10:42 PM
mop300ex's Avatar
do you ride in a lot of water? I do. When you replace the bearings pack them as full as you can. you should repack them twice a year if you ride in a ton of water. I had to replace my whole carrier recently. not very fun. I also had to replace my axle because I bent it somehow.
Old Jun 28, 2000 | 09:03 AM
I probbaly ride in water maybe once every 2 or 3 weeks. I try to keep out of it cause its hard on everyting. later
Old Jun 28, 2000 | 02:20 PM
krabill's Avatar
i put one on my 250x and loved it, havent had a prob yet
91 TRX350X
86 ATC250R
Old Jun 28, 2000 | 08:36 PM
letitsnow's Avatar
Are you sure you aren't overtightening the axle nut?? I've found that it helps to drill and tap the stock carrier for a grease zerk and fill it with grease after the axle is slid through it. This seems to help alot even though they have sealed bearings, maybe it helps keep the moisture out? When you get everything together, your axle nut(or whatever its called on the brake caliper side) should be just a bit tighter than finger tight-then crank the lock nut tight as a SOB.
Old Jun 29, 2000 | 09:05 AM
power7's Avatar
Is the axle carrier the same thing as a axle bearing holder? i have to replace mine and the honda one is expensive. Does any one know of some one who makes aftermarket axle bearing holders?
Matt
95 300EX
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
1000gade
Sep 9, 2015 04:41 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
