To Oil Or Not To Oil (pod filter)
Old Jan 14, 2004 | 10:24 AM
HareScrambleRacer's Avatar
Default To Oil Or Not To Oil (pod filter)
If I'm running a UNI two-stage pod filter with a waterproof Outerwear, do I need to oil the filter element, or do I run it dry??
Thanks for the help!!
Old Jan 14, 2004 | 11:02 AM
95wolv's Avatar
No foam filter can stop dirt without the proper foam filter oil. It forms a tacky layer that traps dirt in the outside of the filter and keep it from going on through to the carb and motor. The Outerwears stops the big chunks and water from plugging up the filter too fast. The Outerwear will keep water and a bunch of dirt away from the filter, but some will still get through, so the oil on the foam will keep that out of your motor.
Old Jan 14, 2004 | 12:07 PM
So do I oil both the inner and outer elements, or do I just oil the outer element of the dual-layer pod filter??
Old Jan 14, 2004 | 12:23 PM
95wolv's Avatar
Just oil it like normal, then put the Outerwears over it, then you're all set for wet and dirty riding.
Old Jan 14, 2004 | 12:32 PM
It's a dual-layer filter though. It has an inner element and an outer "pre-filter" element. Do I need to oil both of these elements, or do I just oil the outer "pre-filter" element?? Thanks!!
Old Jan 14, 2004 | 01:44 PM
95wolv's Avatar
Oil both, the outer one catches the big stuff, the inner one catches fine dust and sand.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
