Throttle cable on a traxter.
Old Jan 16, 2004 | 10:18 AM
zmann's Avatar
Default Throttle cable on a traxter.
Anyone have to change one out yet? Any tips or pointers would be helpful. I have to replace mine asap. Thanks.
Old Jan 17, 2004 | 11:28 PM
zmann's Avatar
no one?
Old Jan 18, 2004 | 01:48 AM
Mdog's Avatar
Never had to change one but had to lube one up after 4 years of use. Mine would,freeze up on me in winter due water getting in the cable. (from power washing).The throttle was stuck wide open, almost slammed into the guy in front of me. The cable lube kit worked perfectly.
Just wondering if your cable is sticking or is totally worn.
If you have to replace it I would remove the necessary plastic panels, cut or loosen the cable ties then black tape the new cable to the old one at the carburetor and try to snake it up to the throttle. I have replaced the brake cable by using the old cable as a snake, worked great.
Old Jan 19, 2004 | 04:43 PM
zmann's Avatar
Well, it is to late for me to do that now. I am sure that was the case before, but, mine is actually broke now.
pgamboa
Dec 24, 2023 11:52 AM
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
craacker
Sep 9, 2015 04:32 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
