removing ball joints????
Old Jun 29, 2000 | 02:18 AM
b(250rman)'s Avatar
Alright I have the upper and lower a-amrs off the left side of my 250r.I already have the new JD performance +2's installed.My question it how do U get the ball joints off???I am looking at my clymer manaul and it says U have to have honda's tool.We have a ball joint remover for cars will that work?Als when we had o get them off my brother in laws van they heated them up with a torch.Any one have any suggestions???
Old Jun 29, 2000 | 12:26 PM
Recondude's Avatar
When i had to replace the one on my recon all i did was there was this little ring on it take this one tool looks like pliers with to funky lookin ends on it and take that ring off and hit it till it pops out
Old Jun 30, 2000 | 11:04 PM
tprender's Avatar
To get the ball joints off the easy way, loosen the nut upor take it off. Get a hammer a hit the area that the bolt goes thought a few times. Don't hit the bolt this might mess up the threads or the ball joint if you want to use it again.
Do you under stand wear I am saying to hit? I was shown this at a national when we had to change a A-arm and I could not get it apart. He hit it 2 or 3 times and it came apart.
Old Jul 1, 2000 | 01:31 AM
b(250rman)'s Avatar
I got them out with the air power ball joint remover all of the came right out.except one I had to work with it a little.
Old Jul 1, 2000 | 04:51 AM
puddding's Avatar
you can fix anything with a hammer!!....you got it right man.....
Old Jul 1, 2000 | 05:09 AM
b(250rman)'s Avatar
If U can't fix it get a bigger hammer!!!!
Old Jul 1, 2000 | 05:26 PM
dudeonit's Avatar
Why would you go through all the expense of installing new a-arms and attempt to change over your 14 year old ball joints from the origonal arms? I am sure by your posting that these units are going to be thrashed as well as potential damage to your OEM arms ( A HAMMER, A TORCH????)
These are steps you take when you don't care about the parts. You either need a press with the proper adapters or an automotive style ball joint tool.
Or if you want to do it right, just buy new units and PRESS them in. Most machine shops can handle this.
Old Jul 1, 2000 | 05:30 PM
300exguy's Avatar
I think he is talking about getting the ball joint out of the spindle like getting the bolt lose from the spindle.
www.angelfire.com/me3/fmf86trx250r
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
89Lt250r
Sep 7, 2015 07:53 PM
