Valve Clearances & Carb. Specs
Old Jan 25, 2004 | 05:57 PM
Muddauber's Avatar
Default Valve Clearances & Carb. Specs
Im working on a 1985 YFM200,Moto4 for a friend. I need valve clearances & carburetor specs, including jet settings, float height, etc. Its all original and stock. Any help is much appreciated.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 5, 2012 | 01:57 PM
markwales's Avatar
me too - hope some one can help us
Old Jun 7, 2012 | 02:20 PM
Raptor450's Avatar
I have a manual here for the 83-85 YTM/YFM 200 and 225.
The valve specs are: intake .05-.09mm (.002-.004 in) exhaust: .11-.15 mm(.0043-.006 in)
The float height is 21.5 mm (.85 in)
Compression should be 128 psi (+ or - 14 psi)
Main jet should be a 117.5
Main air jet is a 1.7
Jet needle is 4DH11 on the 3rd clip position
Needle jet is a N-6
Pilot jet is a 20
Pilot screw is set at 2 turns
This is right out of the manual for a YFM200DXS. There are different settings for a YFM200N if thats what you have.
Old Jun 12, 2017 | 04:38 PM
Vincent Touchette's Avatar
Do you know if it is a vm 28 or a vm 24 ?
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
raman8tor
Sep 20, 2015 07:35 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
