HELP----Raptor won't rev!
Old Jan 26, 2004 | 03:55 PM
8itAgain's Avatar
Default HELP----Raptor won't rev!
Raptor suddenly won't rev beyond 3000 (guess)! This is while running on the flat. It feels as if the rev limiter is kicking in at low revs [img]i/expressions/face-icon-small-disgusted.gif[/img] I checked all the valves for proper clearance, verified fuel flow, removed air cleaner, removed silencer and still the same [img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img] Any ideas???
Old Jan 26, 2004 | 04:00 PM
Raptorx44's Avatar
Loose parking Brake?
Old Jan 26, 2004 | 04:01 PM
RaptorRidrTX's Avatar
Check to make sure your parking brake isn't partly engaged, that would cause that exact problem
Old Jan 26, 2004 | 04:07 PM
Raptorx44's Avatar
I fought with my Brothers warrior for 2 days because of a loose parking brake. Exact same symptoms.
Old Jan 26, 2004 | 04:11 PM
8itAgain's Avatar
I thought about that and traced the wires to the bullet connection below the bars and disconnected it...no change[img]i/expressions/face-icon-small-disgusted.gif[/img] but...do I need to short anything else or connect anything else or just unplug [img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 26, 2004 | 04:15 PM
Raptorx44's Avatar
I believe you have to ground 1 wire. Do a search on Raptor Parking brake or rev limiter and get some more info.
Old Jan 26, 2004 | 04:55 PM
you have to plug the bullet connectors together after you disconnect the wires coming from the lever.
Old Jan 27, 2004 | 03:58 PM
8itAgain's Avatar
[img]i/expressions/face-icon-small-confused.gif[/img] I diconnected the p-brake connector and left hang, I disconnected the clutch bullet connectors and then plugged the bike side into each other...no difference [img]i/expressions/face-icon-small-mad.gif[/img] Off to the stealer to see if they can diagnose and fix...now where did I put that lube......
